Clear the MSDP SA Cache
Clear the SA cache to clear the SA entries the router learns from all peers or a specific peer.
This procedure clears the foreign cache. This procedure does not clear the local cache.
Switch:1>enable
Switch:1#configure terminal
Switch:1(config)#clear ip msdp sa-cache peer 21.0.0.2
Variable definitions
The following table defines parameters for the clear ip msdp sa-cache command.
Variable |
Value |
{A.B.C.D} |
Specifies the MSDP peer IP address. |
vrf WORD<0–16> |
Specifies the VRF names. |
vrfids WORD<0–512> |
Specifies the VRF ID. |
